Like the title says, i am stuck between a custom loop. The custom loop would be for the CPU only until i had enough money to upgrade my GPU. I know a custom loop is overkill for my CPU but, watercoolng looks badass... and expensive. I mainly want a custom loop to sty a bit future proof, if you think i should go with air cooling please will you recommend one for a 4.7ghz+ OC on my FX 6300.
Thanks in advanced, Dom.
My current PC:
AMD FX 6300,
Gigabyte GA-990FXA-UD5
8gb DDR3 Dual Channel 1866mhz,
Sapphire Radeon 7850 Overclocked, (Soon to be paired/Replaced to HD 79X0)
OCZ 650watt 80+ Bronze Non-Modular PSU,
2TB Seagate Barracuda Sata 3 7200RPM 6Gb/s HHD,
Fractal Design Arc Midi R2,
