Hello. I have manage to get my girlfriend into gaming but she doesnt have a computer for gaming so I figured I would build her one out of my various pc parts.
I have installed Win 10 on a Kingston 120gb ssd and have managed to get into windows several times, first with the 1st version of the system which consisted of an amd x6 1090t and gtx 970 (worked quite well actually). But then the computer wouldn't load windows. I have had this problem before on the motherboard I used with the 1090t when using an ssd so I swapped in another motherboard with an 8350 and now I am stuck at the loading operating system screen.
Things I have tried:
Turn on AHCI mode - didnt work
Unplug everthing in the usb ports - didnt work
Reset Bios - didnt work
The specs are:
Amd fx8350
Gigabyte 990x-ud3 motherboard
8gb Corsair vengance 1600mhz ddr3
MSI gtx 970 gaming (will be swapped out for an r9 290 but shoudnt be relevant.)
Corsair HX650 power supply
Kingston 120gb ssd
