Stripped screws:( help please
Hi,
So i have a problem with my Bitfenix spectre pro 230mm fan, it uses a threadless mount for the screws, so when you remove it, it is so tight that the screws strip easily 2 of the screws i can remove, but the other two are stripped clean.
Here are some photos of the screws
http://imgur.com/dPhY2Uo
http://imgur.com/J7Y67iO
As you can see they are badly damaged, so i am wondering are there any easy ways i can remove them, with just a screwdriver as i don't have access to power tools and such.
Thanks for the help :)
Adam
sorry for your luck. but no you will need a drill to get the screws out, from what i saw in the photos.
you can try using epoxy, but you might also have to sacrifice a screw diver and be careful not to get expoxy beyond the screw head.
put epoxy mix on screw head, just a dab. then put screw driver into it and hold it there till the expoxy dries, then try screwing off the screw.
if you have access to the back where the screw is going into you can try using pliers to turn the screw.
easiest would be to use a small drill. good luck.
That sucks.  I hate it when that happens.
Drill methods or epoxy as stated above may work.  If the screws aren't super damn tight, a needle nose plier may work as well.
Ive had luck with using a rubber band before. a Nice wide one that you can push the screwdriver down on and use it for a lil more grip.
I have used cut pliers to grab screws like this and force them open,  you press the pliers until they make indentations on the sides of the screw, then still pressing them turn and the thing should come off.
Just drill it like you would drill a rivet out. Fast, effective, and easy.
"i don't have access to power tools and such."
http://www.sears.com/schroeder-heavy-duty-5-16-inch-rotary-hand-drill/p-00934094000P?sid=IDx01192011x000001&kpid=00934094000&kispla=00934094000P
