Hey guys, so I've been working my way through the original C programming book (K&R) and it's been surprisingly mind-blowing for someone who started on Python and Java a few years back.
I've gotten to the pointers section of the book and one of the tasks is to modify the strcat (string catenation) function to append one char array on the end of another array.
The solution code is as follows:
<code>
#include <stdio.h>
//void cstrcat(char [], char []);
void cstrcat(char *s, char *t);
int main()
char s[100] = "Hello World.";
char t[] = " How are you?";
printf("%s\n", s);
cstrcat(s, t);
printf("%s\n", s);
return 0;
// strcat: concatenate t to end of s; s must be big enough
//char [] and char * are equivalent; preferring char * to
//explicitly state it is a pointer.
while (*s != '\0') {
s++;
while ((*s = *t) != '\0') {
s++;
t++;
</code>
However I don't completely understand the strcat function (named cstrcat here for conflict reasons with the standard library).
I understand that you create an array, and pass it a pointer (which is the variable s in main, acting as &s[0]), but the process somewhat confuses me. Strcat steps through s[] until it reaches '\0' and then replaces '\0' with the first character in, t, and continues to step through t, adding to s as it does so. I just don't understand why I am able to write the function like this:
<code>
s++;
while ((*s++ = *t++) != '\0');
</code>
but not like my initial attempt:
<code>
while (*s++ != '\0');
</code>
Can anyone shed any light on why this is the case? In the last attempt above, the final string is still "Hello World." and the catenation fails to append t onto s.
Any ideas would be great. Thanks.
