So I'm very satisfied with my FX 6300 but feel that when an 8350 goes on sale, I'm for sure picking up one. Now with that said, I want to know if that CPU would be fine for 1080p streaming, or if I should invest in a 3770k or equiv. Haswell i5/i7 strictly streaming rig that CAN also edit and render footage in CS6 if need be.
I would be on a budget and don't want to spend more than 700 if I go a secondary PC route. My backup rig has a Phenom X3 8650 and Radeon 6870 with 6GB of DDR2
Intel does have quicksync but a very popular Tek Syndicate streamer has a dual core Pentium and he tells me that it works perfectly especially if you watch his stream.
with the upcoming 8370, i bet the 8350 gets dropped by maybe $20 to $150ish (ugh.... AMD..... get your shit together..... they keep releasing 8320/8350 bin/overclock CPUs... they already have the 9370/9590, now they are getting an 8370 which is an 8350 with a 100Mhz overclock.)
assuming your motherboard is compatible, i would just go with that, rather then a whole new board and a whole new cpu.
also, i think the 8320 will be dropping to $130-140 at the same time. that is always viable, then overclock.
plus, the 6300 is still a good chip. had my cousin get one earlier this year. you could sell/give it to a friend/family member. or sell it on ebay or something.
Intel's hd series has quick sync, nvidia gpus have shadowplay, and amd gpus have VCE. you can use those to stream instead of the cpu, it has less of a hit on frame rate. The quality will be slightly worse than if you were using the cpu though.
If you live near a microcenter the 8320 is $160 there, dunno about other places
