Streaming Requirements
I've been thinking of starting a YouTube Channel to share my gameplay but I have considered Streaming live to have more interaction with viewers.
My worries are that my upload rate (which is crappy to say the least) will not withstand both streaming and online gameplay. Is there any tips or recommendations you guys have for me to make the best decision possible on the medium to distribute the content.
In short,I would also like to know what benefits or differences there are in having a capture card on my PC over using software based captures like OBS. I've done little research on this and have no real understanding of it yet.
For a good quality stream, you really need at least a 6Mbps upload (for an okay 720p stream). This has been what I found as the sweet spot when I tested this. Unless you really ramp up the compression, but that does take a hit on the computer you are streaming from (unless using a dedicated box)
The software is good to use, as long as you have a powerful enough PC to stop it from lagging the game. (Also best to record to a drive that is only used for recording) A capture card is a better option if you wish to play the games maxed out or if your PC is not the best. Putting the capture card in another PC and using it to record an output from your GPU will greatly reduce the load on the game system.
1. You can run a "test" stream to twitch to see if you're dropping frames then adjust your bitrate/res as necessary
2. You might be better off starting on Youtube anyway, as to build a fanbase. Once you have some loyal fans you can throw in streaming and see how your fans respond.
3. OBS will impact cpu performance GREATLY, I probably wouldn't like it unless I'm using a fairly powerful cpu (a recent i7 or one of those amd octacores).
4. Capture cards will hardly affect your performance at all, your HDD will probably be the most notably affected. Capture cards (the good ones) also tend to be fairly expensive (where OBS is free).
Good Luck, Hope I helped.
