I experience a strange problem with my MacBook Air when streaming Spotify to my Apple TV. After 45 mins or so, the sound starts cracking up. This happens regardless if I connect both units via cable, wireless or a mix of cable and wireless.
However, if I stream music of my iphone 6 via Airplay, the music is conveyed perfectly.
The equipment I’m using is as follows:
Macbook Air (late 2014)
Apple TV (4th gen)
Amplifi mesh HD router
iPhone 6
Equipment also on the same network:
Dell XPS 15" (9560)
I have checked the performance on my Macbook Air and it never runs hot or throttle.
Nonetheless, you should be able to launch spotify, or any app, from the terminal, just by typing in ‘spotify’, and watch the output for possible errors.
I’m not sure why, but it doesn’t work. I only receive an error message stating “command not found”.
“Reduce Loud Sounds” already" is already off. I have also tested with lower volume on the Macbook (level 5 of ouf 15), but the cracking sounds still appear, just as before.
