So I just recently replaced the Cooler Master Sickleflows that I originally put on my H100 with 4 Corsair SP120's in push/pull, and it looks like they have dropped my temperatures by at least a few degrees.
At the same time, and I noticed this with the sickleflows too, two of the cores are significantly warmer than the other two. Is this normal?
I have an Intel Core i7 2600K overclocked to 4.5Ghz, and here are the minimum temps:
Core 1: 37C
Core 2: 29C
Core 3: 36C
Core 4: 33C
Aren't cores 1 and 3 running a little hotter than they should be or is this just normal?
This is nothing to be worried about. I've got a 3930k/H100 and two of my cores are the exact same. It's either due to the construction of your specific chip or the way the liquid runs through the h100 block.
