So, I noticed if I leave a game running, for some time like 5min. The screen goes blank and the MB orange light keeps flashing. Like if the system is retraining the memory. It is stuck like that until I restart the system.
ASUS x370-F Gaming Motherboard
AMD Ryzen 5 2600x OC to 4.3Ghz
Gskill Flare x 16GB 3200Mhz 2x8GB sticks OC to 3466Mhz
EVGA SSC GTX 1060 OC to +150Mhz on GPU clock +600 on the Memory clock.
Both GPU and CPU are water cooled by EK water blocks and rads, using 2x240mm PE series.
Had prime 95 run for about 4hrs with no issues and memtest86 latest done 4 passes with no issues.
Issue only happens on pop_os latest version, running wine
I second this suggestion. Manually setting my RAM voltage to 1.35V solved all of the weird random issues I was having with my OS, though I was using Ubuntu, not that it should make a difference.
The OS actually matters when you’re overclocking, not so much on milder overclocks but when you’re starting to push it, kernel configurations and OS power management impact stability as well.
Just one thing:
Make sure your system is not trying to hibernate. I have had this Problem with Rocksmith running through wine. Since i don’t use any input devices in that game, just the Audio Input, my system would lock and try to hibernate on longer songs.
This would also explain the drive activity. It’s trying to save the RAM content to disk.
Just a thought as you stated it only happens when you let a game sit for some time.
When you mentioned Hibernate, I assume you’re talking about the Linux option, which is already off.
Funny thing is with all of that said, I have not had the issue occur at all yet. But things can change. However, I do have a suspicion as to what is causing it. That being the power limit that I adjusted by GreenWithEnvy.
Oh yeah, Power Limit is more placebo on Nvidia Linux drivers. You need to tune the OC parameters to something that would work at 100% power limit, not 120%.
I found it does not appear to be a power limit setting issue.
I had changed the power control setting in the BIOS, from auto to Typical current.
Also, I made some GRUB changes to add a parameter nowait.
So far I have not had any freezes but, I will try and replicate the issue with those setting mentioned above. If they are fixed, I will mention here that the above settings had resolved the issue.
Update: The issue still remains, however, this time it happened when I was using the system.
I have a log file for this, but I do not know what I am looking for, but it should near the end of the log.
