Storm scout-Modding time
Open to suggestions
Im thinking cutting another stop in the top of the case same size as the one it somes with i thinks 120mm
Ima drill differnt holes out in the mobo tray area for better wire management.
I got 3 of these green dan in it now. 2 on cpu cooler witch is a coolermaster hh-r612 120mm cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835130019
Other fans are red ones that came with a case Yes my case looks like a christmas tree
on a micro atx mobo was free combo with the fx6100 running a gtx560ti 8 gigs 1333 oced it duh.
So other than that i plan on adding in another front fan Green above the hd bay obvosly blowing in.
Want to paint but not sure on color open for ideas perfer somehing wild but not gay pink shit.
Once again anything goes ill cut more shit out of my case lol.
try to get pics up of what im working with btw
Sounds like a good idea. I did it to my logisys area 51 mid tower and it helped me out. Granted I got a scar on my pinkie from that
I did a mod on the Sniper case and painted it red to go with the AMD theme. Make sure before you paint you get some scotch bright and scuff it up so the paint sticks good. i used a primer to make the color pop more. Good Luck!!
http://www.youtube.com/watch?v=gF1aP0YOh8s&list=UUILBr5lIjnxUHBCkSEoWJ8g&index=1&feature=plcp
Nice case. The color scheme looks pretty sick.
Yea ive painted a car before i no how to sander down, that case u did looks sick. Idk i wanna do something diffrent
well you can go nuts and do alot of masking which im going to do next weekend.
when i saw the words CM SCOUT, i hopped to this page immediately. Its the coolest looking case that ive seen. despite its short comings
