I want to add a H710P to a build. Mostly as a plex/backup computer. The intent is to have a Windows OS on the M.2 and add the H710P for a Raid 6 storage drive.
Gigabyte B560M DS3H V2
10400T Intel Processor
Corsair Vengeance LPX 16GB DDR4 DRAM 2666MHz C16
XPG SX8200 Pro 512GB 3D NAND NVMe Gen3x
4 PCIe M.2 2280 Solid State Drive (OS Drive)
PERC H710P Raid Card
SilverStone CS381 case
WD Red Plus drives (5x4tb)
So, I put this together minus the Raid card. Booted fine. Up and running.
Went to add the Raid card…issue.
With the H710P installed, the computer will not boot. Just a beep, a restart, and a black screen. No bios, no H710P bios. Removed the H710P, and the computer will start after a bios statement of changing back to default settings.
I tried the H710P (PCIe x8 I think) in another computer, and the H710p bios popped up like it should.
I tried an old network card (PCIe x1)I had laying around in the motherboard, and it worked. I do not have a PCIe x8 to test in the motherboard.
I updated and installed all the drivers for the Motherboard from the Gigabyte website, except a preinstall sata/raid driver which confused me because this motherboard does not have onboard raid. After this Windows Update found an Intel PCIe driver to update, so I did that.
I updated the motherboard bios to F4.
I tried changing a few of the Bios’ settings before installing the H710P
CSM Support: Enabled
Storage Boot Option Control: Legacy
Other PCI Devices: Legacy
It had been suggested to set the “CPU PCIe Link” speed to PCIe 2.0 …
Tried installing the H710P with and without cables/drives.
I removed the M.2, reset the Bios and with the Raid Card removed, it boots to Bios.
I add the Raid Card, same behavior as above. Tried again with options set to Legacy… same as before. No boot. Same problem exists. Won’t boot with the H710P installed. Works fine without it.
Any thoughts? Compatibility issue? Bad MB? Use another setup?
Well…
I got the tape on pins 5 and 6 on one side per the article. Inserted it and the computer booted. Great.
I looked in the Bios, and the bios sees the card. Great.
However, the card bios (?) did not pop up after the computer bios and before Windows loaded. Not so great. Maybe that is a result of taping off the pins?
I tried enabling CSM, and set a couple options to Legacy, but then the computer would not boot or post.
Removed the card, changed the bios settings back, reinstalled the card and now it boots.
Bios still sees the card, Device Manager sees the card buy indicates drivers are missing. Does installing drivers make sense?
Searching for H710P drivers, under “Dell PERC H710P Adapter firmware release 21.3.2-0005”
I found Update Package for MS Windows 64-Bit. File Name:
SAS-RAID_Firmware_3GWTD_WN64_21.3.2-0005_A07.EXE.
Would this be the correct driver? If so, install it from inside Windows I assume.
Well, the card is in. Computer Bios sees it, Windows Device Manager sees it (no errors). I installed what I think is the correct set of drivers, However there is no pre-windows popup to access the card. Is there a way to set up the Raid from inside Windows?
I have been searching the other articles. Found no mention of the H710 and the B560 chip. Almost all of the articles are about the card are either the card in in a server, or it was flashed into IT mode with no Raid. Also, most articles deal in a Linux environment (not what I am after).
I would like to try the Megaraid software, but I guess I am inept as I have found apparently a number of “cross over” LSI model numbers to the H710P. I found a software version in the 'range" of what the card could be and gave it a shot. MegaRAID Storage Manager 17.05.06.00
Downloaded it. Unzipped, read the txt file about how to get Java installed for this. Played with installing Java, playing with environmental paths, installing the software, uninstalling the software, reinstalling the software… nope.
Upon installing the MegaRAID software, I get two “CreateProcess failed.” errors. Followed by an InstallSheild Wizard note that says is installed successfully. After hitting finish, I open the MegaRaid Storage Manager and…
Windows cannot find ‘-DVENUS=true’ or some other path error. Upon restart I get another CreateProcess failed error. And a CMD popup that shows
"JRE PATH = “C:\Program Files (x86)\Java\jre1.8.0_321\bin”
startCmd in main = “C:\Program Files (x86)\Java\jre1.8.0_321\bin”\bin\java.exe -classpath Popup.jar;…\GUI.jar Popup.Communicator ajsgyqkj=
Well, due to a lack of progress and knowledge I am abandoning this route. I do have this same issue in a couple other forums as well, but I have not had any luck their either. FWIW, I ordered a SATA card and am going with Windows Storage Spaces. Not fast, not what I want. But it will work, albeit a bit slow.
I’d like to solve this. but I have to move on.
felixthecat and ZebraOverlords, thanks for the interest in the thread.
Here is how to get MSM 17.05.06.00 working for anyone that needs it. For me specifically it was to get rid of legacy version with log4j:
Download the latest version of AdoptOpenJDK 8(This is technically the JRE 8u345 B01 x86 at the time of writing): OpenJDK8U-jre_x86-32_windows_hotspot_8u345b01.msi
Install to C:\JRE
Set JRE Home Path Variable(Assuming you don’t have other Java installed)
Example command: SET JRE_HOME=C:\JRE
Install MSM 17.05.06.00 as normal. There should not be any CreateProcess failed errors.
Now here is the key before launching MSM the fist time to get this working. Run the msmUpdate.exe from the MSM install folder. Wait for ~30 seconds.
