Now to my question I just bought the CPU AMD FX-8350 and for the cooling I bought the Cooler Master Hyper 212 Evo which I'm having second toughts about because:
For one TBH I don't think I'm going to be overclocking and people say the stock heatsink will be fine for non overclocked CPUs
I was reading the manual of the FX-8350 and i found out that if you use an aftermaket heatsink that voids the warrenty.
It only costs like 25 quid so is it really going to make much of a difference?
It saves me the hassle of having to apply the thermal paste and as a first time builder I'm afraid I might do it wrong.
So I'm considering just selling the hyper 212 and using the standered what do you think?
Ok then but I'm worried about two things the thermal paste... I hope i do it right i'm going to use the method were you place a small pea sized blob of thermal paste then you slowly set the heatsink on top then screw it down so hopefully it will work but my other worry is what if something goes wrong with the cpu i cant get the warrenty
