It can give you a fair boost depending in what you use the computer for.....its hard to quantify it as the amount you can overclock changes from chip to chip (silicon lottery)
All the K CPUs from intel are designed to be overclocked, but it defiantly a case of getting a after-market cooler....the kraken is getting really good results from the benchmarks iv seen online.
It become really easy to overclock the CPU now days.....youtube if full of really good video guides www.youtube.com/watch?v=UCIWTX-jy9A
The stock fan will be fine for you, but I personally wouldn't be comfortable with it because I've seen CPU temperatures go over 80C when the CPU is stressed with the stock cooler. I would personally at least get a Hyper 212 Evo or something, but that's just me.
Alright,thank you guys!:) I will just go with the stock cooler for now to see that the PC will actually work when I'm done. Then i will ask a friend of mine who's really in to this stuff to help me with the kraken!:)
Not directly, but it can. It also depends on what kind of cooling system your graphics card has. If it's a reference cooler that just has a single blower fan and a long shroud that covers the entire card, then most of that hot air is going to be vented out the back of your case. If you have a cooling system with dual fans and an open shroud, then most of that hot air is going to be vented inside your case.
As long as your case has good airflow, it really shouldn't make much of a difference to your CPU temperatures though.
for a first time watercooling user the kraken is good stuff, also having a mate with you in person, to help with the install and too walk you though oc'ing your chip for the first time is a great idea. you will learn quicker and pick up stuff that you did'nt know before.
well going by the bios preview iv been looking at, yeah it does look pretty simple, saying that 1155 cpus are simpler to oc than the older sockets. less stuff you need to mess around with.
saying that also the newer biosis are more user friendly than the older one's like what im use to lol.
