Sticky motherboard - Dead?
Hey everybody,
I just got myself the following parts:
  • Gigabyte GTX 770 (2gb oc version)
  • Intel Core i5-4670K BOXED
  • Thermal-Take Berlin (630Watt)
  • Fractal Design Define R4 Black (ATX)
  • MSI Z87-G45 Gaming
  • DDR3 8GB 1600-999 Ripjaws K2 GSK (2x 4GB)
Now i tried starting up the system and it worked...for 2 hours...today i tried again and it didnt power up. I looked at everything tried without the graphics and tried again...Nothing happened...I looked at all the parts again ...
  • Cooling was okay... Thermal paste installed
  • Power supply seemed okay aswell
  • Ram correctly installed
  • All connectors were plugged in (8 Pin hasswell thingy aswell)
Now comes the weird part:  The motherboard was sticky on the back!</strong>
Now i wonder: May it be the motherboard which is broken or are those parts not working together that well?
Could that damaged my CPU / GPU or done any further damage?
Hope you can help me in any way!
With best  regards ..  a very sad Cyber
P.S: This is my first build!
The only part in the motherboard that could cause it to get sticky is if the electrolyte from the capacitors leaks, you could check if any of the capacitors look inflated or broken.
Another option is that there was a sticker and the remaining glue is making it sticky.
Regarding your sticky motherboard, a Google search pulled up many forum posts indicating soldering flux residue from the manufacturing process to be the culprit. I would suggest researching flux removal techniques after getting assurance from the manufacturer that such a cleaning (with water or other solutions) will not void the warranty, otherwise try to RMA the board for a clean one.
