Sticky: BSOD instructions
well, seeing as we get a number os "help me with my BSOD" posts, I feel we need some guidance.
so, if you want help with your bsod:
FIRST: upload the .dmp files from c:/windows/minidump
several of us forum members have software that can read the dmp files and tell us the cause.
then, start the tests while you wait for a reply:
use AIDA 64 for the CPU,
Uningine Heavean for the graphics
Seatools or WD diagnotics for your drives
and finally, run at least 8 passes of memtest 86+ (it's a bootable)
some common causes I see frequently:
  • outdated BIOS
  • outdated SSD firmware -especially OCZ drives
  • MotionJoy: the software is quite bad, and well known to cause BSODs
I have to disagree with you there. You shouldn't just say its a bad software. I've never had a BSOD problem with it before. You shouldnt generalize a problem to a program like that. It will cause everyone who ever has a BSOD with Motioninjoy installed to immediately go to that program and blame it, when it most likely isnt the cause.
But yes. Everyone should upload their dumps so we can take a look at them. Will make it a lot easier to help people.
I have had a BSOD problem since the the 1st of FEB. How does one upload the file?
dropbox or me.ga
I would but i decided to just reinstall windows. It was a ATI driver problem from a beta driver i tried and it didn't go very well. I plan to stay away from all beta drivers now.
