I'm not talking about simple upgrades. What if I want to keep my OS intact on the drive and switch out the board/cpu to Intel from AMD? I imagine that you can clone or image before the upgrade, but that seems like it might be a little too complicated over an OS reinstall...not to mention the image stands the chance of being enormous depending on the size of the steam library, though dual drives might be an option too.
better off doing a fresh install. the left over files that were ment to work with the previous hardware might interfere with the current one.
Hopefully it handles game content well enough that you can use a secondary drive...or better yet, a raid and do a simple os restore and not have to reinstall everything.
Oh, you sweet windows users.
You can switch out every part of the system and linux will run without ever giving a shit. All drivers are bundled in the kernel so it just works with whatever you throw at it. You can even change the hardware while it's still running.
I've found that to not be 100% true every time, though that was 5+ years ago and I haven't had to migrate since (fedora mind you). Sometimes a disk controller driver isn't there and the majority of the time, the graphics driver needs updated. That's the reason I ask. This has to be an easy process for new users, such as the Ubuntu proprietary driver install at the click of a button. If it's too much of a pain in the ass to upgrade, people won't like it. I also wonder how Steam will update. Will it use a package manager and use it's own repos, piggyback on another distro and throw a nice little logo up for them, or will we see something else?
That's only true for proprietary graphics drivers. Changing from radeon to intel to nouveau is no problem at all. To change from a proprietary driver to a free driver you need to uninstall the proprietary first...
And if the driver for a disk controller is missing it means either that the module wasn't build or that it's just not supported. Both are rare cases.
Anyway, way easier than windows which requires a reinstall of the whole OS under all circumstances if you change the hardware.
That isnt true. I've changed my motherboards before, even from AMD to intel.
All you have to do is uninstall the Harddrive controllers before you switch out the parts.
When you install new drivers for new hardware, most of the time, it overwrites the old ones.
But sometimes it leaves old cruft on the system, it gets slower or begins crashing. And even if it doesn't, you have to find the drivers first. You need to know what components you're using, then download the drivers from somewhere, if you're lucky your Ethernet port doesn't even work because the driver is missing and all that kind of shit nobody want's to deal with.
You're right though that it can work without re-installation but it's kind of risky.
That's why I brought up imaging too. With windows (vista, 7, 8) , you can take an image with something like imagex or mdt...as long as it's .wim based imaging...and inject drivers and save your install, though any proprietary graphics software such as the nvidia or ati control panels will have to be removed if you are switching graphics vendors. Regardless, the machines will still run almost flawlessly with either still present and the uninstall can be done after the imaging process is complete.
Hardly a simple process by most people's standards and definitely too complex for 90% of the people who will be interested in THIS particular product. Just another reason Steam went with linux, I reckon, though I do think they'll have their hands full with new hardware support...it's not like the Steam client updates everyday anyway or anything like that.
