when i run it form a konsole i get this output
when i try to open steam it won’t open if i do it form a terminal i get this back
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1568566542)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
/usr/share/themes/Breeze-Dark/gtk-2.0/widgets/entry:70: error: unexpected identifier ‘direction’, expected character ‘}’
(steam:135378): Gtk-WARNING **: 19:59:29.582: Unable to locate theme engine in module_path: “adwaita”,
/usr/share/themes/Breeze-Dark/gtk-2.0/widgets/styles:36: error: invalid string constant “combobox_entry”, expected valid string constant
(steam:135378): Gtk-WARNING **: 19:59:29.587: Unable to locate theme engine in module_path: “adwaita”,
Steam: An X Error occurred
X Error of failed request: GLXBadContext
Major opcode of failed request: 151
Serial number of failed request: 52
xerror_handler: X failed, continuing
X Error of failed request: BadValue (integer parameter out of range for operation)
Value in failed request: 0x0
Serial number of failed request: 51
X Error of failed request: BadMatch (invalid parameter attributes)
Serial number of failed request: 53
crash_20190916195928_1.dmp[135417]: Uploading dump (out-of-process)
/tmp/dumps/crash_20190916195928_1.dmp
crash_20190916195928_1.dmp[135417]: Finished uploading minidump (out-of-process): success = yes
crash_20190916195928_1.dmp[135417]: response: CrashID=bp-1ec8a7e3-f53a-405a-8c6a-135752190916
crash_20190916195928_1.dmp[135417]: file ‘’/tmp/dumps/crash_20190916195928_1.dmp’’, upload yes: ‘‘CrashID=bp-1ec8a7e3-f53a-405a-8c6a-135752190916’’
/home/nonetrix/.local/share/Steam/steam.sh: line 720: 135378 Segmentation fault (core dumped) $STEAM_DEBUGGER “$STEAMROOT/STEAMEXEPATH" "@”
[nonetrix@arch-x86 ~]$ /home/nonetrix/.local/share/Steam/steam.sh: line 720: 135378 Segmentation fault (core dumped) $STEAM_DEBUGGER “$STEAMROOT/STEAMEXEPATH" "@”
bash: syntax error near unexpected token `(’
