Steam not letting me login
I launch up the steam login and I type my password and username and it just doesnt load. I can go onto my other account but not my main one. it also doesnt let me login on the steam website.
If you're having problems logging into Steam, you might want to try going through their support and forums to try and rectify the issue. Here's a good place to start: https://help.steampowered.com/#HelpWithLogin
You can try deleting ClientRegistry.blob from you steam folder but as you say you cant login to the website i don't think it would change anything. As Aezen says you should probably get in touch with steam support.
Check the firewall, steam install regularly updates that require authorization. Check your blocked programs; or try dis-activating the firewall or Webb control.
I have McAfee SAAS, and it happens often; I just ok the program; often it is the steam error reporting module that sticks.
Recently I had to fuck around to be able to reach one of my spare accounts. It seems they (Steam) had some intrusions during the holidays (i think).
Hope this helps.
only other thing that comes to mind is the permissions aspect; that causes problems often.
keep me updated
