Here are the specifications for Valve's 300 prototypes.
The 300 prototype units will ship with the following components: GPU: some units with NVidia Titan, some GTX780, some GTX760, and some GTX660 CPU: some boxes with Intel : i7-4770, some i5-4570, and some i3 RAM: 16GB DDR3-1600 (CPU), 3GB DDR5 (GPU) Storage: 1TB/8GB Hybrid SSHD Power Supply: Internal 450w 80Plus Gold Dimensions: approx. 12 x 12.4 x 2.9 in high
These are some pretty crazy specs right there fellas.
Hey if thay whant to send me a box with a titan in it i will beta test the crap out of that lol but seriously these valve boxe's are going to very expencive it seams.
And NVidia+linux? nvidia better pull off some miracles to get the drivers working corectly.
so much for making lower end cheaper hardware run fast on linux...i thought that was the hole point of running a dedicated os and linux.
It kind of makes sense to use Nvidia in this case. You don't need a new kernel for gaming really and the OpenGL implementation of the Nvidia blob beats the performance of AMD's catalyst OpenGL implementation most of the time. It's just that NVidias free driver (eh, the community driver for NVidia cards) is so fracking bad and that NVidia just doesn't care at all about openness, open source, free software and linux (the kernel).
Yup, it's like I said earlier in some thread, Valve is going for a "feature freeze" kind of linux base, like Android. Not that I care, technology evolves, I evolve with it, that Valve wants to stay behind, is there problem.
Think ill be looking at price, could end up buying one just to strip parts and dump in a diff build if the package ends up cheaper than individual parts.
