Well this is my steam box/LAN/Mining rig
The plan is simple, use a hard drive i have and download the lite coin mining software, then use the SSD to load SteamOS and use that as a Steam box. I will swap them using the hot swap bays on the HAF XB
http://pcpartpicker.com/p/2HJ4V
Any comments or changes?
(These parts are all found in my nearby retailer in Singapore so that is why I am using those)
I like the HAF XB because it matches my HAF 912 Adv. and it is small and (hopeful) easy to carry around.
