Static when recording as well as a new wireless headset "snow" problem
Hey guys,I have Plantronics 380 while using a dolby 5.1 usb soundcard to make the volume louder so people can actually hear me and I get a bit of static issues while recording.
Now recently at PAX AUS I won a Corsair H2100 wireless headset but whenever I plug it in I get static/snow sounding interference and I have no idea on how to solve it while using corsairs software.
They've told me to send it in as they think it could be a defective product but I'm doubtful. But if I got a replacement and the same issue occurs I don't think I would be able to sell the headset on something like Ebay.
http://img03.taobaocdn.com/bao/uploa...pg_310x310.jpg    -USB Dongle im using
http://www.gamingcapacity.com/wp-con...com380-911.jpg   -Plantronics 380 headset
 Any ideas? I would prefer my first issue to be solved first before the corsair if possible thanks
If you wish to know my computer specs here they are
Motherboard Asus P8Z68-V
Case: Silverstone raven RV02-E
PSU: Silverstone 850W Silver
CPU:i5 2500k
GPU: Amd Sapphire Radeon 6950 2GB
RAM: G.SKill DDR 3 8GB
It might be an earth issue?  Does it get worse when you move your mouse and drag windows around the screen ect?
I had the same problem with my system untill i got a usb isolator.
Here is the thread relateing to my earth/ ground issue.
Do you mean to say if my computer is on the ground? Cos its on a table about a metre high. I don't think it gets worse for my PC when I move my mouse around. with the 380 I mean
Plug it into something else like a phone
Theres no static when listening on the phone either, its not when listening really, its when I record with the mic it seems to just have a little static on it... Because you are using different headsets would you still be able to hear it if I sent a recorded test to show you what I mean?
Dont use the dongle ? Static can be cause by many issues but in your case it sounds like something is being set (amped) up to high
The problem is if I don't use the dongle the mic is extremely soft, i have no idea how i can make it work at least to a hearable level. This is when i plug into the motherboard sound card anyway which i believe is using realtek if you know anything about that maybe you could give me some instructions? Oh yeah if i do turn on microphone boost to 10-20+ in the control panel/sound the noise still happens.
EDIT: I think ive been misnaming my problem. I think the problem is White noise a friend informed me
