my pc has been assembled and all is well but everytime i plug in a monitor it wont detect anything ive tried 3 monitors and doubt it would be anything else apart from a power supply that might be underkill.ill list the specs incase it helps.
althon x4 760k
msi 660
an old seagate barracuda (although i doubt its the problem as it wont post anyway???
i was wondering if i need to have the driver cd in or something?? im not sure ive tried everything i can think f and getting really frustrated
Are there any beeps with the motherboard speaker attached? If so how many?
Is your ram in the correct slots? (check your manual for placement of a given number of dimms)
Have you checked that everything has the correct power cable inserted?
.. best to diagnose with the motherboard on a table barebone with 1 stick of ram, keyboard, psu, no hdds, & of course the psu. If there continues to be no display, swap out the gpu with a spare one. Swap out ram. Check the cpu has been installed correctly and that the cpu fan is connected to the cpu fan header (odd yeah but some boards dont like it with default bios settings).
If the psu is underpowering the rig, turf it asap. Low quality dirty power will shorten the life of components and may even damage them.
