No I haven't I'll check them out tho thanks for that info my man
Never missed a case before but I already have all the parts in mind that I'm going to be getting. Right now I'm prepping the case it's almost finished just needs a good sanding on the inside and the plexiglass motherboard tray and Bondo then I will be done. This project is going to take a few months I am aware of the cost I'll be using an hdplex pico PSU and a 220watt ac power brick most likely a Pentium chip and a low profile GPU. I'm going to cut holes for venting on the sides and back I removed the flip open tray thing and will be adding mesh to it instead. Thanks for the suggestion but I'm pretty confident in this project it's not too out there in terms of modding IMO.
Yeah if all goes well I think I'll try and add a little LCD screen ontop some how to make it more portable ahahaha
Nice. I've seen a nes build where the person added a lcd to the underside of the top cover, so you could open it up like a laptop, which was pretty neat.
