Okay I think this is the 4-5 post regarding start up problems I am having with my custom built PC, since changing power supply I have had problems with my PC starting up or waking up as I get a blue screen saying an error related to 'iaStorA.sys'. Since getting this error message I have been searching the internet and playing around with my computer and its defiantly related to my SSD which I am using for caching that was set up using Intel Rapid Storage Technology. Currently I have removed the SSD and done nothing to the RAID settings at all and everything now boots up fine without having to restart. Question I am having is, if I format my SSD then install it again and use Intel Rapid Storage Technology to set up caching again will I still have start up problems or do I have something wrong with my SSD hardware? I'm really confused and so any help is appreciated.
No idea but I've seen something like this before on forums about Intel's caching. I don't have Intel but I've been using this with no problems even though it is in beta.
Okay Ill give Primo Cache a try. When selecting the volumes to be cached, is that the HDD you select with all the data on or the SSD which will actually make the caching possible? I'm a noob with building PC's from scratch if you hadn't noticed haha.
You set up a new cache task. Then pick the drives to be cached. Then it'll ask about L1 and L2 caches for L1 you leave it on defaults. For L2 you click manage L2 drives, then format the ssd you are storing the caching.
For the other options I use 4 kb block size. optimize read and write. LFU-R for what data to keep and the defer right with the default time.
it'll look like it's not running in background but it does even after hitting x, and start ups at boot.
I may have forgotten some options, it's been a while since I set it up. Just respond back if you have any troubles. Good Luck.
