Well let me first start of with my parts list that I have come up with.
Case: Fractal Define R5
MOBO: Asus Z97-A
CPU: Core i5-4960K Devil's Canyon
GPU: EVGA GTX 970 Superclocked 4GB
RAM: Corsair Vengeance 16GB
PSU: Corsair HX 750W 80 Plus Gold Modular
SSD: Samsung 840 Evo 250GB
HDD: WD Black 2TB
My budget for this build will be up to around $1500. It will be mainly used for gaming, programming, and as a host machine for Linux in VM Workstation (Ubuntu 14.04 LTS and Kali, often at the same time). I would like to be able to run StarCitizen at respectable settings and be pushing to an Oculus with good frame rates. I also currently play a lot of Arma 3 and Elite Dangerous and would like to run those with the Oculus as well. My current laptop (GTX 680m) is capable of playing those two on high settings but, I can tell it is at its limits in some areas and it flat-out cannot run StarCitizen the way I want it to. I do not plan on buying the Oculus dev kit unless the commercial release gets pushed further than the speculated release of mid 2015 and therefore cannot tell what the resolution of the Oculus will be at that point. The system will be primarily used in 1920 x 1080 until I get myself another monitor, which at that point I will be pushing to both 1920 x 1080 and some other, likely higher, resolution. Will this system be capable enough for StarCitizen in the Oculus or should I just get the 980? Possibly 970's in SLI? 980's in SLI would push me out of my budget. Also is there anything in my list of hardware that could be too excessive for my needs and could save some money on without sacrificing much performance for my needs? e.g. RAM, PSU, CPU, SSD, etc. keeping note that I do prefer Intel and Nvidia at the moment. Some things that cannot be changed are the case, the amount of RAM, the size of the HDD. Also, I need an SSD because I have been using one for a couple of years now and I just cannot go back to not having one... I do plan to do some overclocking. Any constructive help is greatly appreciated!
-rh0mbus
