I'm doing a new build soon in a Define S case that would have a 420mm radiator on top and a 280mm radiator in front and I plan to install both radiators in a push configuration. This yields five static pressure intake fans with a possible sixth fan (airflow type) in the blank spot in front on top of the 280mm rad. The issue I'm trying to determine is exhaust. I know already that six intakes and one exhaust is well into the positive pressure side of the spectrum, but I'd like to increase the exhaust output to remove more of the warm/hot air sitting inside the case, preferably without having to resort to a noisy high RPM fan.
A couple years ago OC3D did an interesting (though highly impractical) mod with an H100i where Tom took 40 120mm fans and stacked them so that there was 10 fans on each fan mount on the H100i radiator. His experiment was of course in the name of science but the overall result was that he was getting CPU temps in the negatives (Celsius), presumably because of the insane airflow.
There was quite a bit of fan noise in the video, however 40 fans redefines extreme in my book.
My question to the cooling community is this: if I were to stack 2x 140mm airflow fans for my rear exhaust port would there be any significant increase in air flow over a single fan? Say, 30-50%?
