i got samsung 960 evo m.2 500gb window 10 edutcation
not sure is this thing https://imgur.com/sSL9qSQ
try looking through all the option in detail…should be there.
Looks similar to this
SB.PCI0.RP09.PXSX
You need to copy the patched kext + ssdt-nvme-pcc.aml to the installed drive EFI partition. Make sure to add the ssdt-nvme-pcc.aml to the ssdt sortedorder of the Config file
Did you create the spoof HackrNVMeFamily.kext for that version of OS X?
add the kext to /EFI/Clover/kexts/Other
add the SSDT_NVMe-Pcc.aml to /EFI/Clover/ACPI/patched
add the the SSDT_NVMe-Pcc.aml to Config.plist under SSDT sortedOrder
No…
You need to go to device manager and go to storage and format your drive as NTFS.
why do i need to format it has fresh window 10 education
Ahh my mistake. I must’ve misunderstood you.
So if you are using that SSD and it has windows installed on it, what is the issue? Does it not work or something? You didn’t describe your issue well enough. You just said “this things, need to do this”, without really asking a question.
Please elaborate on your issue.
it usb that runs hackingotsh that i need ssd nvm controller bios to spoof it and kext part in the other folder in clover file i found how to it kinda
