Hi, I just booted up my new pc and installed windows on the SSD. How do I get the PC to recognize the 1tb HHD I have installed? I have a Samsung evo 120 gb ssd for the os and a few other things, and a WD 1tb 7200rpm HHD for everything else. I have an ASUS M5A99fx Pro r2.0 motherboard and I've been in the bios and looked around to try to change my fan speed and to get the other HDD to working.. but I have no clue...
https://www.youtube.com/watch?v=qMo8krAJd5Q Just because of way he promotes the community.
Thanks! I really appreciate it.
By the way I learned a neat trick recently. You can change the location of libraries in Windows like "My Documents" so that they can live on a separate hard drive, etc. Using this method I could use my old documents folder with game saves, etc from the old hard drive.
Here's a link about how to do it if you wish.
If you are gaming you can also create a second steam library on your 1TB drive for large games, etc.
Good luck with your new build.
I used this back when I did it, really helpful do recommend.
Thanks I'll look into that. I'm currently downloading BF3 to my 1TB HDD. It said the file size was around 19gb.. so definitly not going on my ssd..
