Im having issues with one of my SSD, its a VisionTek Racer 480GB, it disconects randomly when in use, i have tested various Sata Ports Data/Power and keeps happening, i also tried to use an external USB Enclosure, same issue, do you know a way to fix it?
i was looking for the Firmware update but couldnt find anything on the VisionTek Page.
Yeah i will try again, already tried on 3 Different PC same issue, it disconnects randomly from time to time, and i cant RMA since it was used from Ebay but thanks anyway,
I don’t even think Drugga1 uses VisionTek no-name SSDs.
Get your data backed up pronto, wipe the drive, get a replacement, and expect your replacement drive to have problems too.
Well its not mission Critical and i currently have 0 Information on the Drive, it was Cheap and 480GB, i tested the Drive for Speed and its on the 850evo level, but well i will try to contact the Support to atleast try with a Firmware update, like 1-2 years ago i had the same issue with an Adata Sx900, i contacted adata and they provided a Firmware that fixed the issue.
