Srewdriver for zenbook prime UX32VD
Hello teksyndicate
I have purchased the new ux32vd, and i want to upgrade the memory. However, i cannot seem to find a screwdriver with the correct tip. Does anyone know what size/standard those screws in the ux32vd are? Or just a hint in the right direction?
Any help will be very much appreciated :)
i don't have one and i have never seen one in real life, but my guess is that it uses a torx screwdriver.
PLS CORRECT ME IF I'M WRONG
http://en.wikipedia.org/wiki/Torx
http://www.newegg.com/Product/Product.aspx?Item=05A-0001-00069
Thank you for the answer. However i still need to know what bit for the torx screwdriver is the correct one? How small a bit is needed?
Torx #5 I believe.
It was indeed torx 5. Thanks.
