I have been looking at this Anti-Keylogger and wanted to get some second opinions on it. What do you guys think?
Any and all advice and perspectives welcome.
I think stuff like this is dubious at best. A good AV should be all you need to protect yourself from most threats. That said if someone wants your stuff and has the knowledge and will to get it, you wont stop them with software. I dont run AV or related software on my machines because in the end the best security you can have is your own brain. I realize that doesnt work for everyone though.
If you want to go AV shopping these guys do a pretty good job at testing them.
Thank you for the response. I suspected this would be an opinion that I would run into.
What would be the best method to get a keylogger that is already on my system off?
Also thank you for the source site, I have Bitdefender and they seem to check well with them. What do you think of Bitdefender?
The best security is not your own brain at all
common sense 2019 edition is a real quick way to get caught with your pants down.
Av is suplimental to good practice. doesn’t mean you shouldn’t have one.
Most Avs can spot keyloggers as they hook into specific components. Do you notice any odd process names running or console.exe ( assuming you are on windows) if you do you can find the file locations and see what they are running from.
With all due respect… You don’t know me or what I know. I’m not talking about common sense as much as best practices. Relying on software for your security even supplemental is a joke. It stops the Lions share of idiots from themselves but does nothing to protect you from actual threats.
When you can’t maintain security of your own machine to keep people from plugging shit into it or remember your own password to regain access to your account then there’s nothing a piece of software is going to do to help you.
Threads like these often attract those that have little to no idea what security actually means. For that reason I’m going to mute this thread before I get too triggered
I think as far as the ones they’ve tested… Well, close your eyes and point. That one is probably good.
If you believe your machine is compromised, format the drive and reinstall. If it seems to persist, you have big problems. I’m not sure what makes you think you have a keylogger but I suppose it’s not impossible. Starting over fresh is a good way to rid the demons…or at least try to.
Most antivirus/security suites have decent detection of keyloggers, heck even Microsoft’s Defender/Security Essentials has ranked very well for overall protection. Looking at the process names running doesn’t always mean anything, trojans/spyware can run hidden or active processes which run alongside a popular applications.
On the other hand if you’re targeted by a foreign government they don’t use keyloggers, instead they will use BIOS/EFI and HDD/SSD controller level injections for both passive & active monitoring.
I am very uncomfortable doing this myself so I think I am going to have Geek Squad come out and help me with this process.
As for my suspicions, lets just say I have, in the past, been in contact with a very jealous and mentally suspect person whom had capabilities in programming. I have seen signs on different websites which I use that closely resembled my work at extremely coincidental timing.
I am a musician/producer btw. I have all my work on the CPU in question.
While I don’t rule out that foreign governments may have me in their crosshairs for various reasons, I don’t think the culprit is of the sort.
The person in question is a former partner.
I did notice in the task manager I have two console window host running. This sometimes becomes 3
Update: So I know for a fact that my copy Microsoft Office has the Winword.exe keylogger on it. How should I proceed?
Install a selection of av’s run them all one after the other if they don’t pick up anything but you are not sure then format disk. If for any reason you feel that is not enough replace the disk. I would be very surprised if a normal person would put something on your box thats deeper than disk level.
