Hey
I have been thinking of building a proper home server/nas to replace one of my IBM X3550 M3 1U servers from that role. My intention was to try to save quite bit of power over the long term.
I was thinking something along the lines of a nuc-like device, but with those the problem is that you can only fit a single 2,5" HDD/SSD device in them. On top of a M.2 drive.
My intention is to run truenas scale, with a jellyfin and nextcloud instance. So some power required.
I also came accross these ITX motherboards with embedded laptop CPU’s. The problem? Most of them are gemini lake celerons with embedded heatsinks. I am not sure if they are powerful enough for my use case. Ram is cheap, so that isn’t going to be a issue. Looking at this SKU mostly(
https://www.asrock.com/mb/Intel/J3455-ITX/
But I am not sure If I can make that make it. With only 4 sata ports. And I was thinking of installing 2x 4tb ironwolf 3,5" drives. And I already have an existing ATX PSU. And buying a node 304 case for the NAS.
