I'm trying to spec out a freenas box that will be used to back, media server, and aid in compilation. Wouldn't be surprised if I end up running a jail as well, and a sql database at some point. I'm sure it's going to be one of those things where if I have the hardware I'll find a use for it.
According to their hardware guide it sounds like they recommend an SSD over usb boot device for the newer versions. I could of sworn on the freebsd guide they recommend SAS as well. I have a 256 gb ssd that'll be free for this usage. Would prefer to use something smaller, but I don't have one of those lying around.
For my use case I believe I'll need 2 cpus. These are the Motherboards I'm trying to decide between.
SUPERMICRO MBD-X10DRI
SUPERMICRO MBD-X10DAL-I-O
Really not sure, if those are the right boards to use. Have any other suggestions? At the absolute most I think I'll pick up 2 e5-4620 v3.(probably going a bit cheaper if I should stick with 2 chips) Don't know if that would be the best chip for my workload though. The only reason, I'm debating going that high end is for a multichip compilation setup using 3 cpus (really any cpu free on the network) for cutting down on c++ library compilation time. It would be nice if I'm using templates, or a library uses a ton of them.
In what use case would you suggest a FCLGA12 socket over a 2011-3? I'm kind of overwhelmed by the server stuff and compatibility with freenas.
I'll be running wd reds, and an SSD cache for them. Should the cache size be 1 to 1?
I'll probably have somewhere from 64 to 128 gb ecc. Don't know if that's too much for my use. Still need to figure out how much I'll need initially, and how much hdd space I'll have.
Think a 1,000 watt power supply is too much? Trying to hit that 30 to 50% spot so the thing will stay quiet. Think I'll have any luck getting a noctua nh-d15 on / how quiet are the supermicro heatsinks?
Think that's all I have planned out right now.
