Specific OC for 2-core workload
I was wondering if there is a way to override CPU boosting. When core usage is high, like >70%, it will boost to it’s maximum boost. But as soon as the usage drops to <50%, it will lower the frequency. I would like to modify this to say, whenever the core is at >50% usage, boost to max, and also, stay there for at least few seconds before lowering the frequency. I know this was possible on intel i-core many generations back with some unofficial windows app. Is this possible also on AM4 ?
edit: if i remember correctly on intel what i did was edit the p-states settings, meaning, i changed how agressive the system is in lowering the p-state depending on cpu usage. Meaning, i made it less agressive in lowering the p-state.
That’s not really an ‘oc’ but rather frequency governor behaviour. I guess you could move to a high performance setting on windows, perhaps experiment with governor settings on linux. That extent of manual control (by cpu usage) is not possible though AFAIK. Benefits will also be VERY limited. Boosting algorithms are pretty complicated on modern CPUs and factor in a lot of things. And they’re not really user configurable. See the intel degradation debacle, and how long it took them to fix. The only thing the OS can do is ‘hint’ if they are more interested in performance or power. And you can keep temps down or undervolt a bit, that helps too.
Im only looking into this because of this special 2 core usage, basicaly only 2 cores are getting used. And there is not much i can do apart from that +200Mhz boost override and xmp
If you want to go extreme you could switch off all cores except for (the best) two and do a manual OC. But that is highly specific and will reduce performance a lot for other tasks.
There won’t be that much to be gained probably. Modern CPUs already boost quite greedy. Highly doubt it’s worth the effort
i think also for this type of approach to work on modern multicore processor you need to assume the process stays on a certain core, most modern cpus, change which core is boosting to “move” where the high power is, moving the heat to a new area to keep temps in check.
