I think this is "other" hardware. If not, point me toward the correct place.
Anyway, I've got a bit of a strange issue. To understand, you'll need three important bits of context.
- I suffer from fairly severe chronic muscle spasms that give me problems on a daily basis.
- I spend my working day at my desk, as well as recreation (gaming, netflix, crunchyroll). This adds up to 9-12 hours a day at my desk.
- I'm 6'1" and not overweight.
I realize that the first two points in combination bring up some correlation v. cause issues. Let them be, please, I know what causes the spasms. It's genetics, sadly, and bad luck.
On to the problem you needed that context to understand. I have a ~$100 desk chair from Wal-Mart. Objectively, it's quite nice and solid. However, it doesn't fit my needs.
I need to find a replacement that fits certain particulars, and a budget, and I am hoping you guys can point me in the correct direction without me running down the particulars myself.
- Lumbar support (preferably structural)
- Chair back extends enough to support my head beyond the next item
- Neck support (again, preferably structural)
- Large enough to support my tallness without a problem
- Not built for someone who's heavy, if possible, I don't want to drown in it like I do in the "For Big & Tall" type one I do have
- Costs less than $500. Preferably less than $350.
- Not going to collapse after a mere year of use.
I don't care about leather, brand name, racing/gaming styling, ability to recline to insane angles, or whether it works well with simulator setups.
So, anyone able to help?
