Speaker system for gaming PC
Hi all, this is my first Forum post! :D
So I'm looking into buying both a new sound system for my PC.
And I really don't know a thing about audio...
Firstly, I think I'll be running off onboard sound on my ASUS Z87-A mobo - should I get an external amp even if the sound system has a sub-woofer? I've not used the onboard sound before so anyone with experience with this mobo please weigh in. I doubt I'll be buying a internal sound card though. Too much noise even on 'shielded' cards.
Secondly, what speaker system should I get? I've looked at a few creative and logitech ones already, and I'd rather not spend much over £50. But I have no idea whether or not 2.1 or 5.1 surround is best for gaming - I really don't know a thing about audio, if I'm honest. So guys, please give me advice! :)  Oh and no I won't use a headset/pair of headphones, I prefer to game with nothing on my head (yes that also includes hats), so speakers please! :)
So yeah... Help!?
My neighbor has the logitech z506 if you're willing to spend that much on 5.1's. They are very cheap on amazon in america But since the logitech uk sale i think that they're even cheaper over there.
Ok so your mobo supports up to 7.1 surround. Now it's a question of what you value more, power or accuracy. I own the Logitech z506's and they kick pretty good for $100 (£60). If you want even more power than you can go with what Gr33nL34f mentioned for £97. As for gaming I would recommend the z506s. They are the cheaper choice but it's ultimately up to you. They will give you surround, which is good for gaming. What is your setup like? Are you just going to put the speakers in front of you?
They're only about £60 here, which is a great price for 5.1s. how do your neighbors speakers sound then? I'd assume that from Logitech they'd be good sound and build quality, but you never know
Accuracy 100%. Power is nice, but I have a baby sister who I'd rather not wake up and I also like the sound to be as intended. I'd definitely like surround yes, but 7.1 is probably excessive for the size of room I will be in - 5.1 is better I think. The speakers will be on a desk, probably spread out on the surface around me to give some good surround. I wouldn't be opposed to having them wall mounted though.
This is the desk: http://www.ikea.com/gb/en/catalog/products/70214192/#/00214181
The monitor will be in the middle with my PC sat behind the pull out section :)
