To put in my room for music mostly. I would use my ipod to select the music.
Im pretty sure they are bare wire.
Other than that info im a giant noob and need to know what else i need (amp or reciver?) to make this thing work. I would not want to go over 120 dollars including the speakers
You would need a receiver to connect them to, if you don't have that you obviously can't get speakers for 110$ and stay within 120$...
I'm not sure what you're trying to do, are you expecting to just connect your iPod to the speakers and listen? If so these are completely the wrong kind.
I found speakers from my attic that my dad bought about 25 years ago. Could a reciever make these speakers work because the end of the speakers are bare wire please reply soon because I want to order today afternoon. Would these speskers still sound good?
Bare wire doesn't matter it's just + and - like all speakers, it's just that most modern speakers have sockets that follow a standard (RCA as an example). Same thing is fed through the connections though. Just like with all plugs and sockets.
