Sparkle Arc Pro B60: only 150 GB/s VRAM bandwidth (spec 456)
I’ve been testing dense LLMs on my B60 and they seem to run at half the speed of some other reports - Qwen3.8-27B Q4_K_M at 8.6 t/s, against 16 t/s on other B60s with the same llama.cpp build and flags.
Troubleshooting with claude led me to a potential issue with vram bandwidth.
Testing with clpeak –global-memory-bandwidth I got the result - 150 GB/s.
If another B60 owner can run the same test and let me know I would really appreciate it.
Here is my Sparkle Arc Pro B60 result
.\clpeak --global-memory-bandwidth
Backend: OpenCL
Platform 0: Intel(R) OpenCL Graphics
Device 2: Intel(R) Arc™ Pro B60 Graphics
Driver version   : 32.0.101.8976
Compute units    : 160
Clock frequency  : 2400 MHz
  Global memory bandwidth
    float    : 400 GB/s
    float2   : 419 GB/s
    float4   : 431 GB/s
    float8   : 438 GB/s
    float16  : 442 GB/s
GPU BIOS version: 23.0.1061
OS: Windows 11 26H2 x64
clpeak version: git commit #b5da524
Thanks a lot, now at least I know my GPU is faulty.
If you don’t mind, please test your B60 with my arcinferzero, it’s on Github rizagp/arcinferzero
I made updates specifically targeting B60
