I have this soundcard i bought for gaming that i feel is useless because when i start a game or a program, this weird whiny noise comes up.
Its so bad there is no point in plugging anything into it. So i use normal ports on my motherboard instead.
1: What is the noise? and how to fix it?
2: Do i need to have my headset plugged in to the soundcard port to have any affect on the sound i get? I might consider selling it if there is nothing i can do about it.
Sounds like noise from the system is leaking in to the audio source. You can try a different expiation slot. And if you have the front panel thing you can try the connection on the back of the sound card.
I have tried both the front panel and back panel and both make the buzzing noise. and okay Ill check later if i can possibly move the card to a diff slot to see if it works.
whining noise= coil whine. Your problem is that your soundcard isn't your problem, it's probably a problem of your motherboard or graphics card. The cards is already pretty well shielded, there is not much you can do but rearrange your power leads in your PC and hope that by dividing the load in a different way, it will be solved. Repositioning cards also sometimes helps.
I ground the case itself directly to the outside GND connection, that usually helps with these kind of issues.
