as my name states I'm a retard in some subjects and my question is can I use a pci soundcard as a pass through for my xbox360. I plan on using to run an Toslink cable from the console to the soundcard and connect the red and white cable to my speakers ( Logitech z506 ). Is this possible?
I use my USB soundcard to run my Xbox audio to my headphones, so yes it is possible, but it depends on wether or not your sound card is able to take an input signal. My onboard card only has 3.5mm audio input, my USB soundcard, however, has optical, 1/4", and composite audio in. Just make sure you're plugging the console's audio into an input on the soundcard, and not an ouput.
If you're on Windows, you can then make the sound playback through your speakers by right clicking the volume icon, going to recording devices, select the input you used for the console, hit properties, go to the "listen" tab, and check the "listen to this device" box. If you want it to only ever play through your speakers, you can select them in the "playback through this device:" dropdown menu.
If you need any help (or if I wasn't clear about something) I can go into more details.
I like USB over PCI most of the time, I'm currently using one of these but if you want passthrough with it, you have to also hook your speakers up through it or it will have a huge lag in the audio.
I haven't looked in a while, but the last time I looked for a soundcard with optical input, they were all rather expensive.
If you're willing to deal with lower quality audio, you should be able to buy an adapter from component audio to 3.5mm and use your onboard mic imput for passthrough. That's what I used to do, but the cables I used made a constant buzzing noise.
I don't really have a good recommendation for you, but as long as you find one that has an input that you can convert your console's audio to, you should be fine.
