I was originally going to get the Fractal Design R4, but I've heard from places like Anandtech that there isn't much clearence for a H100, so a H100i is probably not going to fit. I want a quiet case, with good cooling and room for a H100i. Any suggestions would be greatly appreciated.
Well as I suggested before, you could get a Noctua air fan which cool as godd or better. :)
Thanks for the advice! I've been researching for hours and it seems I overlooked the P280. I think I'll stick to the H100i though, I've looked around a bit and the general consensus is it's cooler. However I might use some Noctua case fans since I've heard they're very quiet and have great performance.
How well do these cool though? Now as a complete noob the cases like this(without ventilation in the side) seem like they would just be hot as hell.
A H100 should definitely fit.
http://www.youtube.com/watch?v=vwgVA6_xIis&feature=youtu
He fit a 280mm rad on the front and there is juuuuust enough space for a 240mm on the top.
I got a corsair 550D which is super quiet and has the perfect mounting for the H100.
http://www.corsair.com/us/pc-cases/obsidian-series-pc-case/obsidian-series-550d-mid-tower-quiet-case.html
