Sound card vs onboard
hi guys, what's the main points for and against a sound card vs onboard mobo audio for gaming/music.
You'll really have to listen in person to the difference mate. But once you hear how good something like the Asus Xonar STX is compared to onboard sound, yeah you'll be blown away. When sound is processed by a DAC it becomes alive with colour, and the clarity is nuts. I have a Xonar stx myself and I couldnt believe my ears the first time I heard a high quality audio clip through it. Overall the amount of sensory pleasure that you get from decent sound is worth every penny of a sound card.
Do make sure though that the speakers and or headphones are good as well.
Main points for onboard- it's there, it works. Points against - sound is so-so, prone to EMI, more prone to other noise.
Sound card - usually better sound quality (EMI shielding, better SNR, broader frequency response, etc.), and depending on model and your own sensitivity to sound, can be a huge night and day difference and can make all media much more immersive. Personally don't have a sound card, but I have a USB headset, and I tend to prefer that just from all the EMI of my integrated sound (both front and rear audio). Points against - extra investment, can be expensive, takes an expansion slot, may require better audio equipment to fully utilize.
Even a basic add-on card can make a big difference from what I hear. Again, I don't own one; I'm mainly regurgitating what I've been hearing repeated over and over again on forums and tech videos.
ASUS has a SupremeFX sound technology on their ROG mobos, which is basically branding for combination of isolating/shielding the sound circuitry, bigger/better capacitors, etc, that allow a basic integrated audio chipset to perform optimally, and there quite a few people who like it. I'm personally skeptical since their SupremeFX is powered by a Realtek audio chip, but I don't doubt it sounds better than most on-board audio.
