currently using onboard realtek whatever on asus m5a99fx pro and i can get one of these [link] for $15, so what do you think, for $15 if i can get even slightly noticable better audio quality and better noise placement in games it sounds like it might be a good idea, and i've heard nothing but good things about creative
There's not going to be much point to buying one of those and using it with $20 headphones. Save up for some Audio Technica ATH-50s or Beyerdynamic Custom Ones, then buy an amp or soundcard.
i wasn't, i hsppen to notice something i could get for almost nothing, and figured if i could improve audio quality and positional audio for $15 then i would get it
I see. I can say for sure you have no use for that thing then. The onboard audio on Asus boards is not great by any stretch of the imagination, but in this situation, it is your headphones that are acting as the "bottleneck" so to speak.
