Sound card help!
hey all,
I have the ASRock Fatal1ty 990FX Killer and I see it comes stock with the Realtek ALC1150 soundcard. I was wondering if this sound card was good enough or if its worth it to upgrade to a dedicated sound card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157479
lets say my max budget is 100 but if there is something that is great for lets say 60$ or so i'd prefer the cheaper.
what would you guys suggest? i'll mostly be gaming and some light music production
The sound on those boards are fairly decent actually. Most sound cards, especially for $60-100, are useless and you won't be able to tell the difference between them.
What do you plan doing with it?
