Sound Card Help
 hey i'm stuck between a Asus Xonar Essence or Creative Sound Blaster Recon3D Fatal1ty Champion
i have heared great things from Asus Xonar's and this essemce is my price range but Creative Sound is cheaper and the Champion has 5.25 front pannel box ( forgotten the proper name )
Now to make thing even easier there also another Asus Xonar but i have never seen this one anywere and i have some problem find clear reviews.
i shall link all produces below and also like my build
Creative Sound Blaster Recon3D Fatal1ty Champion:
http://www.amazon.co.uk/Creative-Blaster-Recon3D-Fatal1ty-Champion/dp/B005IHNS5O/ref=cm_cr_pr_product_top
Asus Xonar Essence:
http://www.amazon.co.uk/Asustek-Xonar-Essence-Channel-Express/dp/B001P9O894/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2YHKLHYXKXC8B&coliid=I39S9K1WFL9Y0D
The other Asus Xonar:
http://www.amazon.co.uk/ASUS-Xonar-D2X-XDT-Express/dp/B0011BC1FO/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=2YHKLHYXKXC8B&coliid=I2G7A932VJ5MLS
my build:http://pcpartpicker.com/uk/p/srPH
BTW im from the UK
Depends what function you plan on using it for.
Creative cards are not very good, and there software is pretty awful.
The Essense is a fantastic headphones sound card, but you need pretty good set of headphones to really benifit from it.
The other one is a 7.1 channel set, so it might not have a headphone amp, but it would work with decent computer speakers. Wouldnt use it with an actual sound system or headphones.
IF you just want a good headset card, I would look at a Xonar card with a headphone amp. All do a pretty good job at what they do.
