Can you please recommend a case that is windowed, supports Atx case, also in which I can put 2 120mm fans on the top and a 140mm exhaust, maybe an led fan in the front if possible, I want one for £50 or less.
I want to put a Cooler Master 212 Evo on the build but pc part picker says it doesn't fit..
I wanted to get this case at first.
http://www.amazon.co.uk/Corsair-Carbide-Spec-03-Micro-Computer/dp/B00J63KSJA/ref=sr_1_2?ie=UTF8&qid=1404689316&sr=8-2&keywords=spec+03
Anyway in the other hand if you can recommend me a good cooler that will actually fit in this case with the same sort of price to the hyper 212, that will be great.
The cpu I am using is a Amd fx 8320 and a R9 280
