it’s the hardware module that makes some expensive there are some cheap monitor’s with ones and the module it’s about 100-200$~ I think and they complete monitor with it is 300$-350$ 🤷 but there is also newer g-sync module that supports 144hz at 3840x2160 with hdr that is like 500$ just the module and with monitor 1200$
If you run the cards as they come factory out of the box,
then i assume that there wont be much an issue on hand here.
But of course wenn start messing around with overclocking then you could run into problems.
Thats why overclocking shouldnt be used for advertisement for cpu’s and gpu’s alike.
Because its missleading, same counts for overclocked benchmark numbers.
Yeah but that could also be just a bad pcb that rolled of the production line.
And of course it all depends on where the exact root cause of the issue lays.
Board partners, pcb manufacturing processes etc.
Normally if you run them within specs they came out from the factory,
they shouldnt really fail.
But of course hardware failure can allways happen.
Thats why overclocking part of reviews are missleading.
People believe if they buy the same card as Gamers Nexus got for review,
that their card can overclock to the same numbers.
But that is never really guaranteed.
That’s just a bad multi-layered ceramic capacitor. Same issue as the 1080 FTW. The person just happened to get a bad capacitor. The PCB wasn’t at fault, it was the supplier of the multi-layered ceramic capacitors at fault. (Which was the case with the 1080 FTW)
I’m kinda out of the loop and went offline for awhile, so i hope you don’t mind me asking this question:
Is it safe to get an 2080 or even 2070 ? or they all have this issue ?!
