Some one HELP Me!
I have had to install windows vista 32 bit because my friends copy of windows 7 doesnt work for some reason so can some one help me get a activation key for windows vista 64 bit because i can get the disks for it and i need it so bad because i cannot use all my 6 gb or ram so plz help me GET A KEY!! for vista 64 bit . thanks
Sorry man, RTW doesn't openly support piracy, you're better off asking elsewhere.
DOOM this is not piracy, windows 7 is in beta, and is open. Dude if you go to the windows site and look up a windows 7 64 bit download, they'll give you a key.
He wants a vista key, read carefully.
