[SOLVED] Wireless card is treated like ethernet port
After the latest Arch Linux update my wireless card is now showing up as an ethernet port. This means that I cannot easily connect to wifi (I have to do 'sudo ifconfig wlp7s0 down && sudo wifi-menu' and then it's shown as wired connection). Is there some way to force the OS to treat the wireless card as a wireless card?
Solution:
Just had to run "sudo ifconfig wlp7s0 down && sudo wifi-menu", connect to wifi and reboot
