Hello!
I have 2 drives in my computer and I want to reinstall my Windows. If I reinstall my Windows, will it also remove files from my other drive?
Do I have to disconnect my other drive for it not to get formatted?
Hello!
tl;dr no
No, you can choose the drive (or even the partition) that you want to format when you reinstall windows. Just make sure that you only format the C drive, then the other drive will be totally fine.
Thanks!
